How Do I Use the Extended Display Feature on my Approach R50?
The Approach® R50 launch monitor can extend the display to a projector, TV, or monitor by using the Audio/Video (A/V) port on the back of the Approach. This can be helpful if you want a larger screen to view details such as data fields, ball impact data, a video of the ball impact, or the ball path after taking your shot.
Connecting the Approach R50 to an External Display
If your projector, TV, or monitor has an HDMI® port, you can use an HDMI cable to plug the Approach directly into the display.
If your projector, TV, or monitor has a DisplayPort™ you will need to use a powered HDMI to DisplayPort Adapter as well as a DisplayPort cable. This type of adapter requires a USB power source to be able to function.
Once the Approach R50 is plugged in to your external display you are ready to use the extended display feature.
Steps to Use the Extended Display
When the Approach R50 is plugged in to your external display you can use the extended display feature:
After selecting the mode you want to use, press Start Session.
Select the club you are using.
Press the button on the lower right corner of the screen.
Select External Display.
Select one of the following options for what data will be displayed:
Map: Shows you the virtual course or range and the ball path after each shot.
Data Fields: Shows various data points related to your shots.
Ball Impact Data: Shows data points relating to your previous shots ball impact.
Impact Video: Shows you a short video of your previous shot, highlighting the impact made with the ball.
NOTE: Selecting Mirror R50 Display will mirror the entire display of the Approach onto your projector, TV, or monitor.
