Pairing a quatix® Watch to a Garmin Chartplotter
The quatix® watches can display data fields streamed from a compatible marine chartplotter.
To stream boat data on a quatix® watch, the Boat Data app must be installed to the watch using the Connect IQ (CIQ) mobile app. See How to Install Connect IQ Content Using the Connect IQ App for more information.
Marine Activities and Compatible Marine Devices
Device | Activities | Compatible Devices |
quatix® 3 Watch | Native: N/A CIQ: Note: See the CIQ store for more devices that support CIQ apps Autopilot Boat Data GNT™ 10 NMEA 2000® Transceiver Fusion® Audio (Fusion-Link) | Autopilot
Boat Data
GNT™ 10 NMEA 2000® Transceiver |
quatix® 5 Watch quatix® 5 Saphire Watch | Native: N/A CIQ: Note: See the CIQ store for more devices that support CIQ apps Autopilot Boat Data GNT™ 10 NMEA 2000® Transceiver Fusion® Audio (Fusion-Link) | Autopilot
Boat Data
quatix® 6 Watch quatix® 6 last mango Watch quatix® 6X (solar) Watch quatix® 6 Titanium Watch quatix® 6 DUEL POWER Watch | Native: Boat Sail CIQ: Note: See the CIQ store for more devices that support CIQ apps Autopilot Boat Data GNT™ 10 NMEA 2000® Transceiver Fusion® Audio (Fusion-Link) | Autopilot
Boat Data
quatix® 7 Watch quatix® 7 Sapphire Watch quatix® 7 Solar Watch quatix® 7 Pro Watch | Native: Anchor Boat Fish Fish Forecast (Pro Only) Sail Sail Race Expedition Tides Trolling Motor Wakesports Activities
CIQ: Note: See the CIQ store for more devices that support CIQ apps Autopilot Boat Data GNT™ 10 NMEA 2000® Transceiver Fusion® Audio (Fusion-Link) MFD Remote | Autopilot
Boat Data
GNT™ 10 NMEA 2000® Transceiver MFD Remote
quatix® 3 Watch : Pairing to Compatible Chartplotter
To begin pairing the quatix 3 to the chartplotter the following steps are needed from the chartplotter:
Home
Select Settings
Select Communications
Select Wireless Devices
Select Garmin Wearable
Select Enable Connections: On
Select New Connection
To conclude pairing, on the quatix 3:
Tap the MOB/Start button
Tap the down button until Boat Data is highlighted
They should now be paired successfully
Tap OK on the chartplotter
quatix® 5 Watch : Pairing to Compatible Chartplotter
The quatix 5 can display up to 3 data fields per page and up to 4 pages of data.
To pair the quatix 5 with a compatible chartplotter:
Bring the Garmin watch within range (3 meters) of the chartplotter
From the watch clock screen of quatix 5, press the START button.
Select Boat Data
Note: If the watch is connected to a chartplotter and you would like to connect to a different chartplotter, open the Boat Data screen, hold the Menu button, then select Pair new
On the chartplotter, select Communications
Select Connect IQ Apps
Select Boat Data
Select Enable
Select Connection. The chartplotter will search for and connect to the quatix 5
If the code shown on the chartplotter matches the one shown on the watch, select Yes to complete the pairing process
After the devices pair, they automatically will connect when they are turned on and within range.
quatix® 6 Watch : Pairing to Compatible Chartplotter
The quatix 6 can display up to 3 data fields per page and up to 6 pages of data.
To pair the quatix 6 with a compatible chartplotter:
From the watch clock screen of quatix 6, press the MOB button
Select Boat Data
Press the MOB button
Note: If the watch is already connected to a chartplotter and you would like to connect to a different chartplotter, open the Boat Data screen, hold the Menu button, then select Pair new
On the chartplotter, select Settings > Communications > Wireless Devices > Connect IQ™ Apps > Boat Data > Enable > New Connection
The chartplotter will search for and connect to the quatix 6
quatix® 7 Watch : Pairing to Compatible Chartplotter
The quatix® 7 smartwatch includes the ability to display up to 3 data fields per page and up to 6 pages of data.
To pair the quatix® 7 watch with a compatible chartplotter:
From the chartplotter select > Settings > Communications > Wireless Devices > Connect IQ™ Apps > Boat Data > Enable Connections
Before selecting New Connection follow the steps 2-5 to place the quatix® 7 watch into pairing mode
Bring your quatix® watch within 3 m (10 ft.) of the compatible chartplotter
From the home screen of the watch face, press the START button
Select the Activity to pair and press the START button
For this pairing select Boat Data
While the watch displays "Searching..." from the chartplotter select New Connection
"Connected to boat" displays on the watch screen when the two have paired successfully
After the devices initial pairing they will automatically connect when they are turned on and within range.
The quatix® 7 multisport GPS smartwatch includes the ability to display up to 3 data fields per page and up to 6 pages of Boat Data.
Boat Data Categories
Sailing - Data Fields
- AWA
- AWS
- TWA
- TWS
- DIST LINE
- RACE TMR
- BURN TIME
- TWD
- VMG WIND
- TTL
- VMG START
- TTWA
- TBS
- PBS
- ΔTBS%
- ΔPBS%
- TAWA
- ΔTWA
- ΔAWA
- ΔTBS
- ΔPBS
Water - Data Fields
- BOAT SPD
- DEPTH
- SEA TEMP
Navigation - Data Fields
- HEADING
- VMG GPS
- ETA NEXT
- BEARING
- XTE
- DIST NEXT
- DIST DEST
- ETE NEXT
- ETE
- ETA
GPS - Data Fields
- COG
- SOG
Engines 1, 2, 3, 4, or 5 - Data Fields
- RPM
- TEMP1
- COOL PR 1
- OIL PR 1
- FUEL LV 1
- FUEL FL 1
- FUEL EC 1
All Engines - Data Fields
- TTL FL
- TTL REM
- TTL EC
