Navionics Boating: Importing and Exporting
To Export a GPX File to Share by Email, Message, etc., or Open It With Apps Supporting GPX Files
  1. Go to Menu and select Routes, Tracks or Markers
  2. Android: Tap the three dots icon in the top right corner. Apple: Choose Select in the upper right then go to step #4
  3. Choose Select
  4. Select one or more items from the list by tapping the box on the left side of your listed options
  5. Tap the Share button in the bottom left corner
  6. Select Export GPX file
  7. Choose your preferred app to export the file
To Import a GPX File Exported From Another Program or Plotter
If you have a GPX file containing a point or points and would like to import them into the Navionics Boating app, the file will need to be sent in an email or message. This way the file can be opened on your mobile device for importing.
  1. Open the message containing the GPX file to import
  2. Open the GPX file on your mobile device
  3. From the listed apps select the Navionics® Boating app to open the GPX file
  4. The Boating app will open advising you are attempting to import items
  5. Select Import or Cancel from the options
