Connect IQ App Limits on a Garmin Device
There is a limit to how many Connect IQ™ apps can be loaded to a compatible device. This limit can vary by device and is regulated by the Connect IQ Store app, the Garmin Connect™ app, and the Garmin Express™ program.
If you attempt to install additional items when the limit has been reached, you will receive an error message advising you that the limit has been reached and that you must remove some of the currently installed apps in order to install any more.
Why Is There a Limit?
Each Connect IQ app can store additional app-specific data that will take up additional disk space. The limit for your device is based on the possibility of every app taking up additional memory.
For instructions on checking available space for your device, select one of the options below:
Checking Available Space with the Connect IQ Store App
  1. Select My Device (bottom right).
    • If you have multiple devices, select Three blue dots stacked vertically (top right) to switch devices.
  2. You will see available apps remaining beneath "Installed Apps".
    Connect IQ Store app installed apps screenshot
Checking Available Space with the Garmin Connect App
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Garmin Devices.
  4. Select your device.
  5. Select Activities & App Management or General.
  6. Select Manage Storage.
    • If you do not see Manage Storage, use the Connect IQ Store app or Garmin Express to check available space.
Checking Available Space with Garmin Express:
  1. Launch Garmin Express.
  2. Select your device.
  3. Select IQ Apps.
  4. Select the three blue discs stacked vertically icon.
Checking Available Space On the Device:
Some Garmin devices feature a built-in Connect IQ app store. Refer to this FAQ for compatibility.
  1. Open the list of apps on the device.
  2. Select the Connect IQ Store App.
  3. Select Installed.
For more information about what devices are compatible, see the Connect IQ Store.
For more information about syncing your device, refer to your owner's manual.
Related
