Remove Custom POIs from a GPS Device
There are two different ways to remove Custom Points of Interest (POIs) from a Garmin device. The best method will depend on the way that the Custom POIs were originally loaded onto the Garmin device.
If the Custom POIs came from a *.gpi file, the Manual Deletion Method will be needed.
If the Custom POIs came from a *.gpx or *.csv file and used POI Loader to install them, the POI Loader Deletion Method will be needed.
Since both methods can be used to load Custom POIs, both methods may need to be used to remove the Custom POIs especially if one method does not completely remove all of the Custom POIs from the Garmin device.
NOTE: Your device may need to be completely powered off and then back on to remove the Custom POIs after following the steps below.
Windows:
  1. Connect the Garmin device to the computer
  2. Open File Explorer then This PC, (or Computer on Win 7,8)
  3. Open the Garmin or SD card drive
  4. Click on Internal Storage, Internal Garmin Storage (or the Garmin folder on some devices)
  5. Double-Click the POI folder
  6. Delete all .gpi files
Mac OS X:
Note: Files cannot be viewed from the following devices when connected to a Mac computer. A Windows computer is recommended. See Automotive Device Compatibility with Garmin Mac Applications on macOS for information on viewing files on these devices:
    • Arctic Cat G8 Display
    • Camper 780 & Traffic caravan and motorhome sat nav
    • Camper 785 & Traffic caravan and motorhome sat nav with camera
    • Camper 795 caravan and motorhome sat nav
    • Camper 890 caravan and motorhome sat nav
    • Camper 895 caravan and motorhome sat nav
    • Camper 1090 caravan and motorhome sat nav
    • Camper 1095 caravan and motorhome sat nav
    • CamperCam 795 motorhome sat nav with built-in dash cam
    • CamperVan caravan and motorhome sat nav
    • dēzl™ 780LMT-S GPS navigator
    • dezl™ LGV500 and dēzl™ OTR500 GPS navigators
    • dēzl™ LGV610 and dēzl™ OTR610 GPS navigators
    • dēzl™ LGV620 and dēzl™ OTR620 GPS navigators
    • dēzl™ LGV700 and dēzl™ OTR700 GPS navigators
    • dēzl™ LGV710 and dēzl™ OTR710 GPS navigators
    • dēzl™ LGV720 and dēzl™ OTR720 GPS navigators
    • dēzlCam™ LGV710 and dēzlCam™ OTR710 GPS navigators with camera
    • dēzlCam™ LGV725 and dēzlCam™ OTR725 GPS navigators with camera
    • dēzl™ LGV800 and dēzl™ OTR800 GPS navigators
    • dēzl™ LGV810 and dēzl™ OTR810 GPS navigators
    • dēzl™ LGV820 and dēzl™ OTR820 GPS navigators
    • dēzl™ LGV1000 and dēzl™ OTR1000 GPS navigators
    • dēzl™ LGV1010 and dēzl™ OTR1010 GPS navigators
    • dēzl™ LGV1020 and dēzl™ OTR1020 GPS navigators
    • dēzlCam™ 785 LMT-S GPS navigator with camera
    • Garmin Catalyst™ Driving Performance Optimizer
    • Garmin Drive™ 53, Garmin Drive™ 53 & Traffic, and Garmin Drive™ 53 & Live Traffic GPS navigators
    • Garmin DriveCam™ 76 GPS navigator with camera
    • Garmin DriveSmart™ 55 & Traffic GPS navigator
    • Garmin DriveSmart™ 65 & Traffic GPS navigator
    • Garmin DriveSmart™ 65 with Amazon Alexa GPS navigator
    • Garmin DriveSmart™ 65 Traveler's Edition GPS navigator
    • Garmin DriveSmart™ 66 GPS navigator
    • Garmin DriveSmart™ 71 GPS navigator
    • Garmin DriveSmart™ 76 GPS navigator
    • Garmin DriveSmart™ 86 GPS navigator
    • Kawasaki RIDGE 8" Tread Display
    • Overlander® GPS navigator
    • RV 780 & Traffic RV navigator
    • RV 785 & Traffic RV navigator with camera
    • RV 795 RV navigator
    • RV 890 RV navigator
    • RV 895 RV navigator
    • RV 1090 RV navigator
    • RV 1095 RV navigator
    • RVcam 795 navigator with built-in dash cam
    • Tread®, Tread® - Base Edition, Tread® 2 series, Tread® - Overland Edition, Tread® XL - Overland Edition, Tread® - SxS Edition, Tread® XL - Baja Chase Edition, and Tread® XL - Baja Race Edition GPS navigators
    • zūmo® XT and zūmo® XT2 GPS navigators
  2. Open Finder
  4. Open the Garmin folder
  5. Open the POI folder
    • Depending on the model of the Garmin device the POI folder may appear in a different directory.
  6. Highlight all the .gpi files
  7. Drag the .gpi files to the Trash
  8. Empty the Trash
Once finished, all of the Custom POIs files from the Garmin device will be completely removed.
In order to remove Custom POIs from a Garmin Device, the latest version of the POI Loader must be installed Go to the POI  Loader page to get the latest version. Once the latest version is installed do the following:
Windows:
  2. Open the POI Loader program
  3. Click Next on the first screen
  4. The next screen provides a Save Option, choose Garmin Device and click Next
  5. On the next screen, the program should auto-detect the device, make sure the correct unit is selected, then click Next
  6. On the following screen, select Remove all previously installed custom POIs from your device, then click Next
  7. The program will display: To reinstall custom POIs you will need to run POI Loader again. Are you sure you want to proceed?
  8. Click Yes
  9. Click Finish
Mac OS X:
  2. Open the POI Loader application
  3. Select Remove all previously installed custom POIs from your device
  4. Click Continue
  5. The next window will show the device from which the custom POIs are to be removed
  6. Click Continue
  7. Click Remove
  8. A message will display: You have successfully removed all custom POIs from the device
  9. Click Done
