How to Record Sonar Logs With Your Garmin Plotter
Users can record and upload depth information created with the Garmin Quickdraw™ Contours feature to enhance the Fishing layer available on Garmin Navionics+™ and Garmin Navionics Vision+™ mapping products.
Recording Quickdraw Contours
A microSD™ / SD™ card is required to generate and save maps created using Garmin Quickdraw Contours on compatible chartplotters (ECHOMAP™ and GPSMAP® devices)
Striker™ Plus / Vivid units do not have micro/SD card slots. These devices have internal storage allocated specifically for Quickdraw Contour content.
- To find specific settings and recording instructions: Owner's Manual Link
Striker
Select Quickdraw Map > > Quickdraw Contours > Start Recording / Stop Recording
ECHOMAP
From the chart view select Menu / ... > Quickdraw Contours > Start Recording / Stop Recording
GPSMAP
From the chart view select Options > Quickdraw Contours > Start Recording / Stop Recording
Uploading / Contributing Quickdraw Contours
To share Garmin Quickdraw Contours to the Quickdraw Community Contributions sharing must be enabled from within the ActiveCaptain® application on a smart device. Once contributions have been enabled sharing occurs automatically when paired to the fishfinder or chartplotter.
- Open the ActiveCaptain application on the smart device > select Sync with Plotter > under the Quickdraw Community Contributions enable Contribute to Community
- Sync Quickdraw Community Data
