The FLUX S and FLUX 2 come with all the parts and accessories needed to set up most bikes and begin indoor cycling training. This FAQ will explain what parts are included with a FLUX S and FLUX 2.
Select your trainer's axle size below for size specific information.
Type 1: Flux S and Flux 2 What Is in the Box? FLUX S/2 trainer
Power Cord
FLUX S and FLUX 2 (Type 1) Assembly Kit
Quick release drive side (DS) adapters (pre-installed on trainer)
5mm Shimano/SRAM cassette body (pre-installed on the trainer)
Rubber cap set- installed on trainer
Axle adapter kit for TACX FLUX and NEO Trainers (included with FLUX 2 Type 1 trainers)
What Is Included in The Flux S and Flux 2 (Type 1) Assembly Kit? Tacx Universal quick release skewer
FLUX leg bolts
8mm hex key
5mm non-drive side (NDS) spacer for bikes with 135mm rear spacing
Leg bolt washer
Leg bolt washer
Cassette spacer - Used when installing 8-10 speed cassettes on included cassette body. Installed behind the bike's cassette
Replacement Part Numbers Part Description Part # North American Power Cord
S1941.60 FLUX S Type 1 Assembly Kit S0039 5mm non-drive side (NDS) spacer (included in Assembly Kit, Type 1) T2805.16 Tacx Universal Quick Release skewer T1402 Quick release block caps S0041 Type 1 Shimano/SRAM cassette body S0012 Leg set for FLUX Trainers S2900S.02 Rubber cap set S0038 Axle adapter kit for TACX FLUX and NEO Trainers (included with FLUX 2 Type 1 trainers) S0040
What Is Included in the Axle Adapter Kit (S0040) For Tacx FLUX and NEO Trainers? Axle adapter kit for Tacx Flux and NEO trainers contains many options for converting thru-axle bikes to quick-release.
Quick release skewer for thru-axle bikes
5mm M12x1.0 threaded drive side (DS) adapter
5mm M12x1.5 thread drive side (DS) adapter
5mm M12x1.75 threaded drive side (DS) adapter
5mm conical non-drive side adapter
5mm flat non-drive side (NDS) adapter
12mm drive side (DS) end cap
10mm drive side end cap
12x142 non-drive side (NDS) adapter
Type 2: Flux S and Flux 2 What Is in the Box? FLUX S/2 trainer
Power Cord
FLUX S and FLUX 2 (Type 2) Assembly Kit
Non-drive side (NDS) quick release adapter (pre-installed on trainer)
Quick release drive side (DS) adapter for 130mm (pre-installed on trainer)
12 mm Shimano/SRAM cassette body (pre-installed on the trainer)
What Is Included in the Flux S and Flux 2 Type 2 Assembly Kit? Tacx Universal quick release skewer
FLUX leg bolts
8 mm hex key
Leg bolt washer
Leg bolt washer
Cassette spacer
12 mm drive side (DS) thru-axle adapter
Quick release adapter for 135 mm bikes
12 mm non-drive side (NDS) thru-axle adapter for 142 mm bikes
12 mm non-drive side (NDS) thru-axle adapter for 148 mm bikes
Replacement Part Numbers Part Description Part # North American Power Cord S1941.60 Assembly Kit FLUX S/2 (Type 2) S0054 Tacx Universal Quick Release skewer T1402 Type 2 Shimano/SRAM cassette body S0050 Leg Set for FLUX Trainers S2900S.02 Rubber cap set S0038
