Unable to Update Vector Pedals Using Vector Updater
Vector Updater is used to update your vector pedal system with the latest features. In the event that one or both of the pedals are not detected by the application, you will get an error message letting you know which pedal is having trouble.
Select your system below and try the steps listed in order to solve the problem.
Vector
  1. Remove pedals from the bike.
  2. Replace pedal pod batteries.
  3. Inspect each pod ensuring there is no damage to the brass pedal pod contact points.
  4. Reinstall pedals and pods noting to switch pods left to right and from right to left (does not apply to "S" models).
Attempt to update your pedals again. If the problem moves with the pod over to the other pedal, you will need to replace the defective pod.
Vector 2
  1. Remove pedal pods from the bike.
  4. Reinstall pods noting to switch the side each pod was previously installed on.
Vector S and 2S
  1. Replace pedal pod batteries.
  2. Inspect pod ensuring there is no damage to the brass pedal pod contact points.
Vector 3 and 3S
Vector Updater is not compatible with these systems. Please use the Garmin Connect app to update your pedals. The Garmin Connect app allows you to pair your pedals to the app via Bluetooth. Once connected, any available software updates can be installed using the app.
