Correcting Low Volume on Automotive Devices
If you are having trouble hearing the sound coming from the automotive device you will first want to make sure that the volume or master volume is set to an audible level.
To Check the Volume or Master Volume:
- Touch the Volume icon on the Where To? View Map screen
2. Confirm the volume is set to the desired level and it is not muted
On some devices, hit the down arrow on the left to see additional volume settings. Checkmark all desired to have sound.
If the master volume is turned up and the volume is still low, check the volume levels within the Mixer or Audio Mixer to make sure they are set to an audible level.
To View the Mixer or Audio Mixer:
1. Touch the Volume icon on the Where To? View Map screen
2. Touch the Wrench icon or slider icon
- Skip this step on some devices
3. Touch Audio Mixer or Mixer
4. Confirm the desired volume for any that apply: (i.e. Navigation and OK Garmin, Media, Phone, Alert Tones, Camera Alerts, Amazon Alexa, etc.)
The volume level should now be set to the desired level.
NOTE: Audio Mixer is available only after the phone has been paired to the device on some Bluetooth-compatible devices.
Audio Mixer is Available on the Following:
- Avis DriveSmart™ 50 GPS navigator
- Camper 770 LMT-D caravan and motorhome sat nav
- Camper 780 & Traffic caravan and motorhome sat nav
- Camper 795 caravan and motorhome sat nav
- CamperCam 795 motorhome sat nav with built-in dash cam
- CamperVan motorhome sat nav
- dēzl™ LGV/OTR500 GPS navigators
- dēzl™ LGV/OTR610 GPS navigators
- dēzl™ LGV/OTR700 GPS navigators
- dēzl™ LGV/OTR710 GPS navigators
- dēzlCam™ LGV/OTR710 GPS navigators with built-in dash cam
- Garmin DriveAssist™ 50 | Garmin Drive Assist™ 51 GPS navigators with camera
- Garmin DriveCam™ 76 GPS navigator with camera
- Garmin DriveLuxe™ 50 | Garmin DriveLuxe™ 51 GPS navigators
- Garmin DriveSmart™ series of GPS navigators
- Garmin DriveTrack™ 70 | Garmin DriveTrack™ 71 GPS navigators
- RV 770 LMT-S RV navigator
- RV 780 & Traffic RV navigator
- RV 795 RV navigator
- RVcam 795 RV navigator with built-in dash cam
You can also say OK Garmin or Voice Command to adjust the volume on your device. See Garmin's Support Center for tips on using Voice Command.
- NOTE: Voice Command is available on compatible devices only
- Go to Garmin's Support Center
- Enter your device name (Ex. DriveSmart 66)
- Select the Voice Command topic box
- or select Search for a solution... box and type Voice Command
- Select an FAQ for Voice Command tips and help
