Adding, Removing, and Troubleshooting Wi-Fi Connections on Outdoor Handhelds
Some outdoor handhelds1 have the ability to connect to a Wi-Fi network,2 allowing the handheld to download available software updates and gain access to other connected features. For more details on the purpose of Wi-Fi, see Related
Wi-Fi Network Requirements
NOTE: Hidden networks are not compatible.
  • Supported Frequency: 2.4 GHz
  • Security: Unencrypted, WPA, and WPA2
  • Password Length: 8 characters minimum3
Adding and Removing Wi-Fi Networks
In order to configure the Wi-Fi settings on your handheld, you can use either the Garmin Express™ program or you can setup Wi-Fi in the settings on the handheld (refer to "Connecting to a Wireless Network" in your owner's manual for instructions).
Garmin Express
Adding a Wi-Fi Network with Garmin Express During Initial Setup
  1. Attach the Garmin product to computer.
  2. Select Get Started or Add a Device in Garmin Express.
  3. Select Add a Device.
  4. Sign In or Create an Account.
  5. Select Next (can select check box for sending anonymous data to Garmin).
  6. Select Find Networks.
  7. Select the desired network.
  8. Input password (if required).
  9. Select Save.
  10. Select Finish.
Adding a Wi-Fi Network to a Garmin Handheld Already in Garmin Express
  1. Launch Garmin Express.
  2. Select your device.
  3. Select Tools & Content.
  4. Select Utilities.
  5. Select Sign In, then sign in to your Garmin Connect™ account.
    • Garmin Express protects the saved Wi-Fi network credentials on your Garmin Device by requiring a sign in to your Garmin Connect account before Wi-Fi networks can be configured
  6. Select Add a Network.
  9. Select Save.
Removing a Wi-Fi Network With Garmin Express
    • Garmin Express protects the saved Wi-Fi network credentials on your Garmin Device by requiring a sign in to your Garmin Connect account before the networks will be displayed
  6. Select Trash Icon for the Wi-Fi network you wish to remove.
If you are having trouble connecting your handheld to a Wi-Fi network, there are several things that may be causing the issue. Below are some examples of things you can try to resolve this issue.
If the Wi-Fi has been properly setup and shows that it is connected, the Wi-Fi connectivity can be verified with the Active Weather function on your outdoor handheld. Active Weather coverage areas are found  in the following article: Active Weather Coverage Areas.
For best results, make sure to disable the Bluetooth on the handheld before proceeding to check that it is receiving data only through the Wi-Fi. Check your owner's manual for viewing Active Weather or disabling the Bluetooth on your handheld.
1 Compatible handhelds include the Alpha® 200 series, Alpha 300 series, GPSMAP® 276Cx ,GPSMAP 66 series, GPSMAP 86 series, Montana® 700 series, and Oregon® 700 series outdoor devices.
2 A maximum of seven Wi-Fi networks can be added to a Wi-Fi compatible handheld.
3 The maximum password length varies based on the security protocol. WPA-PSK/WPA2-PSK has a maximum key length of 63 characters.
Related
