Reactivating a Suspended inReach Device
The inReach Freedom plan allows you to suspend the subscription during the months you do not want to use the inReach satellite communication services.
When you are ready to reactivate the subscription for your inReach device, any of the plan options are available for you to reactivate to.
- Log in to the Garmin Explore Website
- Select Plans & Devices
- Select Edit next to the suspended device
- Select Reactivate under Plan Renewal Date
- Select the plan you wish to use
- Click on Plan Details within the window next to each selection to view what is included with each subscription plan
- When selecting a plan, you can decided to change from a Freedom plan to an Annual plan. Keep in mind that while Annual plans have lower monthly costs, there is no suspend option. All Annual Plans are activated for a minimum of 12 months
- Sync the inReach device after your subscription is reactivated:
- For steps on syncing your inReach Mini, see - Updating the Firmware and Syncing Account Information to an inReach Mini
- For steps on syncing your inReach SE/SE+ or Explorer/Explorer+, see - Updating inReach Firmware and Syncing Account Changes with inReach Sync
- For steps on syncing your Alpha 200i, GPSMAP 66i/86i/86sci or Montana 700i/750i, see - Syncing an Alpha 200i, GPSMAP 66i/86i/86sci or Montana 700i/750i with the Garmin Explore Website and App
Additional information can be accessed by selecting the Related content below.
