Alpha 200i Not Syncing or Staying Bluetooth Connected to the Garmin Explore App
If you are having trouble getting the Alpha 200i or the Garmin Explore app to sync, or it is not staying connected with the Garmin Explore app, there are a few things to look for.
Check That the Bluetooth for the Alpha 200i Is Turned On
The Bluetooth icon should be displayed in the status bar next to the battery charge indicator.
Confirm That You Are Running the Latest Version of the Garmin Explore App
Check for updates to the Garmin Explore app.
Make Sure the Software on the Alpha 200i Is Up to Date
Use Garmin Express from a computer, which will automatically check for and install available software updates.
Check For and Install Any Available Updates for Your Phone
Consult your phone manufacturer for assistance if needed.
Miscellaneous Items to Check
Make sure that Airplane Mode is turned off on your mobile device.
Select Devices in the Garmin Explore app and verify that the Alpha 200i shows Connected.
Make sure you are selecting the correct sync option:
The sync option in the Account section synchronizes the Garmin Explore app with the Garmin Explore website.
The sync option in the Devices section syncs the Garmin Explore app with the Alpha 200i.
If the Garmin Explore app will sync with the Alpha 200i but not with your account on the Garmin Explore website, check that your phone has a wireless data connection.
Troubleshooting Steps for Connection/Syncing Issues
Attempt unpairing and pairing the two devices again.
Select Forget Phone in the Bluetooth Settings of the Alpha 200i
Navigate to the Main Menu on the Alpha 200i
Select Setup
Select Bluetooth
Select Forget Phone
Select Yes
Select Remove Device in the Garmin Devices section of the Garmin Explore app
Forget the Alpha 200i in the Bluetooth Settings of your phone or tablet
Consult your phone manufacture for assistance if needed
Restart both the Alpha 200i and the phone or tablet
Pair the Alpha 200i back to your mobile device in the Garmin Explore app
