How to Activate an inReach Mini 2
Before you can use the messaging and SOS functions on an inReach device, you must create an account and activate a service plan for the device. If you are having issues logging into your inReach account or creating a new account, see Related at the bottom of the page.
NOTE: Credit or debit card information needs to be provided in order to complete activation steps below.
Activating a New inReach Device
New Users Without an Account
IMPORTANT: These steps are for users that do not currently have an inReach or Garmin account. If you have an existing inReach or Garmin account, use the steps under Existing Users below.
  1. Go to explore.garmin.com.
  2. Select Create a New Account.
  3. Select New inReach Account.
  4. Select the appropriate plan for you:
  5. Enter the inReach's IMEI number and Authorization Code, review the Terms and Conditions and Privacy Statement before agreeing, select the country of your billing address, then click Next.
    Finding the IMEI Number and Auth. Code
    When powering on the inReach Mini 2 for the first time, you will be prompted to select a language, null (or skip), then activate (or skip).
    When selecting to activate, the IMEI number and Auth. Code will be displayed on the screen.
    If you previously skipped the activation prompt:
    1. Press Down from the home page on the inReach Mini 2.
    2. Press OK to Activate Now.
    3. Press OK again to advance to the IMEI and Auth. Code.
    NOTE: The IMEI and Auth. Code can also be found by pressing OK from the home page to access the main menu and then Settings > System > About.
    Orange Next Button Below Country or Region
  6. Enter your name, email, and a password.
  7. Check the box to agree to the Terms of Use, then click Create Account.
  8. Enter your personal information, then click Next.
    • Emergency Notes is a good place to add information of any known medical concerns. If you have additional coverage for medical evacuation or search and rescue, you can include that and how to get in contact with the company providing that service. Example:
      SOS Contact and Information for Medical Evacuation Coverage
  9. Add Emergency Contacts information, then click Next.
  10. Choose between Annual Plans and Freedom Plans.
  11. Select a specific plan under the Annual Plan or Freedom Plan options.
  12. If desired, choose the additional GEOS Search & Rescue Benefit. This is not required. Once finished, click Next.
  13. Review all entered information to confirm it is correct, then click Next.
  14. Check the box to agree to the Terms of inReach Service, then click Next.
  15. Enter your billing information, then click Next.
  16. Follow the prompts to finish activating your inReach device and account, then take the device outside.
It is important to take your inReach outside with a clear view of the sky to complete the activation process. Also sync your inReach with your account after activation, for more information on how and why, see - Syncing the inReach Mini 2 With the Garmin Explore Website and App.
Existing Users
NOTE: Personal Plan accounts are for individuals only and can have more than 1 inReach device with an active subscription on their account, but can only be assigned to 1 active inReach device for use at a time. Before adding an additional device, see - null.
If you are operating as a business or organization and need to add additional users to your account, a Professional subscription is required. For information, see - Difference Between inReach Personal and Professional Plans.
  2. Select Sign In.
  3. Log in to your account.
    • If needed, reset your password by selecting Forgot?
  4. Click on Plans & Devices.
    Alternative Steps if "Plans & Devices" Is Not Available
    1. Select I Have One for the device you are activating.
    2. Select the appropriate plan for you:
    3. Skip to step 8 below.
  5. Click Add inReach Device.
  6. Click I Am Adding.
  7. Read the Important Note, then choose Cancel, Continue to Add, or Create a New Account.
    NOTE:
    If you choose Create a New Account, use a different email address than your existing Garmin account.
    Explore Website Adding an Additional Device Warning Page
  8. Enter the inReach's IMEI number and Authorization Code, review the Terms and Conditions and Privacy Statement before agreeing, select the country of your billing address, then click Next.
  9. Choose between Annual Plans and Freedom Plans.
  10. Select a specific plan under the Annual Plan or Freedom Plan options.
  11. If desired, choose the additional GEOS Search & Rescue Benefit. This is not required. Once finished, click Next.
  12. Review all entered information to confirm it is correct, then click Next.
  13. Check the box to agree to the Terms of inReach Service, then click Next.
  14. Enter your billing information, then click Next.
  15. After you see a confirmation that activation is complete, you may begin to make changes to your Garmin Explore account.
    • Emergency Notes is a good place to add information of any known medical concerns. This is found under Account at the top of the page. If you have additional coverage for medical evacuation or search and rescue, you can include that and how to get in contact with the company providing that service. Example:
    • If you have multiple users on your account and need to assign an additional device to another user or yourself, see Reassigning an Additional inReach Device to Another User or Yourself for more information.
Watch Our Video
IMPORTANT
Registering Your inReach
Your inReach is registered automatically during activation of service to the device, or adding it to your Garmin Explore account.
The inReach Mini 2 receives software updates through Garmin Express. Adding these devices to Garmin Express to update them will also register them. For more information, see - Installing Software Updates to Outdoor/Marine Handhelds
Related
