Setting Up or Troubleshooting Wi-Fi on a Fitness Device
Fitness devices that can connect to a Wi-Fi network allow you to automatically upload saved activities and download available software updates when in range of the network. You will want to first verify if your device is compatible with the Wi-Fi feature.
Compatible Devices
Bounce
D2 Air
D2 Air X10
Edge 1000
Edge 1030
Edge 1040 Series
Edge 530
Edge 820
Edge 830
Edge Explore 1000
Forerunner 245 Music
Forerunner 255 Music
Forerunner 255S Music
Forerunner 620
Forerunner 630
Forerunner 645 Music
Forerunner 745
Forerunner 920XT
Forerunner 935
Forerunner 945 Series
Forerunner 955 Series
Legacy Hero Series
Legacy Saga Series
Venu
Venu 2 Series
Venu Sq Music
Venu Sq 2 Music
Vivoactive 3 Music
Vivoactive 4 Series
NOTE: Some devices support setting up Wi-Fi networks on the device itself. To check if your device supports this, refer to your owner's manual.
What Requirements Does My Wi-Fi Network Need to Meet?
Supported Frequency: 2.4 GHz only
Supported Protocols: 802.11 ac, b, g or n (802.1x is not supported)
Supported Channels: Channels 1-11 only
Security: Unencrypted, WPA, and WPA2
Passwords for encrypted networks must meet an 8 character minimum in length
Networks with a hidden SSID are not supported
How to Add a Wi-Fi Network to a Garmin Device
To configure the Wi-Fi settings on your device, you can use either Garmin Express or the Garmin Connect app. Select an option below to reveal instructions.
Adding a Wi-Fi Network with the Garmin Connect App
Most devices with Wi-Fi will have the same steps within the Garmin Connect app, however there are a few devices that are different.
Adding a Wi-Fi Network with Garmin Express During Initial Setup
Attach the device to the computer.
Select Get Started or Add a Device in Garmin Express.
Select Add Device when your device is found.
Select Sign In or Create an Account.
Select Next (you can select the check box for sending anonymous data to Garmin).
Select Find Networks.
Select the desired network.
Input password.
Select Save.
Select Finish.
Adding a Wi-Fi Network to a Watch Already in Garmin Express
Launch Garmin Express.
Select your device.
Select Tools & Content.
Select Utilities.
Select Add a Network.
Input password.
Select Save.
Instructional Video for Setting up Wi-Fi Connectivity.
Why Does Garmin Express Prompt Me to Sign in Before Displaying My Wi-Fi Networks?
Garmin Express protects the Wi-Fi network credentials you have saved to your Garmin device by requiring you to sign in to your Garmin Connect account before displaying your Wi-Fi networks. After disconnecting your Garmin device from your computer, the next time you navigate to Tools & Content > Utilities in Garmin Express, you will be prompted to sign in again before Garmin Express will display your saved Wi-Fi networks.
Troubleshooting the Connection to the Wi-Fi with My Device
If you are having trouble connecting your device to a Wi-Fi network, below are some suggestions you can try to resolve this issue.
Ensure that Garmin Express indicates that the Wi-Fi network is set up.
Ensure the device software is up to date by syncing with Garmin Express.
If it just updated, you will need to unplug the device from the computer in order to get those updates finalized on the Fitness Device.
Attempt to connect to a different available Wi-Fi network such as a personal Wi-Fi hotspot.
Additional carrier fees may apply. Check with your service provider if you have any questions.
Select Sign In, then sign in to your Garmin Connect account.
Garmin Express protects the saved Wi-Fi network credentials on your Garmin Device by requiring a sign-in to your Garmin Connect account before the networks will be displayed.
Select for the Wi-Fi network you wish to remove.
Confirm the Device is Connected Properly to Wi-Fi
NOTE: Disable Bluetooth if the device is paired to the Garmin Connect app. This will prevent the activity from being uploaded via Bluetooth instead of Wi-Fi.
Record and save a 20-second test activity on your Garmin device.
Wait approximately 30 seconds for the device to establish a Wi-Fi connection and transfer the activity.
If successful, the device will display a message indicating the transfer is complete.
If one minute elapses without the device displaying a message, check Garmin Connect to see if the activity appears.
If the activity appears in the Connect account, Wi-Fi is functioning properly.
Activity Does Not Appear in Connect
If the activity does not appear in Connect, either the Wi-Fi connection is failing, the date on the device is wrong, or Connect is unable to accept the upload at this time
Check the Connect Status Page to verify there are no outages. If there is currently an outage, you will need to wait for the issue to be resolved.
Ensure that the date reported by the device is correct.
If the date is incorrect, activities will be processed and uploaded, but will be sorted under the wrong date in Connect.
If an activity was recorded and the device was away from the Wi-Fi for over an hour, the activity will not automatically upload. You will need to activate a manual Wi-Fi sync on your device.
