Getting Started with the Pro 550 Plus
null
Getting Started
Before you head out to train with your Pro 550 Plus for the first time it's important to make sure that you have charged your system and have a good GPS fix for your location. A GPS fix for both the Pro 550 Plus handheld and any paired collars is necessary to use the training functions of your system. This system is not designed to be used indoors for prolonged periods of time without acquiring a GPS fix and timing.
Depending on how you intend to use your system here is some additional content that is highly encouraged to setup your system properly before your first use.
