Gear Tracking Feature in Garmin Connect
Our Gear Tracking feature in Garmin Connect allows you keep track of the wear and tear of multiple types of gear over time, including running shoes and cycling equipment. You can track how far you've run and assign a total distance that'll flag up when it's time to change your shoes. Cyclists can do the same for bikes to know when it's time to take the wheels in for service. To manage gear in Garmin Connect:
Garmin Connect App
  1. Open Garmin Connect App on your smartphone
  2. Open the Menu:
    • More on iOS
    •  on Android
  3. Touch Gear
    • Touch  to add new gear. After entering gear information, touch Save.
    • Touch Edit next to the name of a gear item to edit, retire, or remove it
Garmin Connect Web
  1. Sign into Garmin Connect
  2. Click Gear from the navigation bar on the left
    • Click to add new gear. After entering gear information, click Save.
    • Click next to the name of a gear item to edit, retire, or remove it
When you choose the option to automatically add a specific gear item to new activities the distance will automatically be tracked for that gear. You can also edit activities to add or change which gear item was used (see Related Content).
Related
