"No Detailed Maps Found That Support Routing" or "Map data is not available" Error Message
There may be a problem with the mapping files if the message “No Detailed Maps Found That Support Routing” is displayed after turning on an automotive device. The message “Map data is not available” may display when searching for a destination. This may cause the device to show only the locations of major cities or major highways with no side streets.
To Correct This Issue:
See the detailed video below to troubleshoot this issue.
Windows
Mac
1. Touch the Settings wheel
2. Touch Navigation
3. Touch Map and Vehicle
4. Touch myMaps
5. Enable the maps
      • The map is enabled if a checkmark is present.
      • Touch the empty box if a checkmark is missing.
      • See the additional troubleshooting below if the map is missing or the page is blank.
6. Touch OK
Additional Troubleshooting if the Map is Missing From the Device or was Already Enabled:
  • Ensure the memory card is inserted and formatted properly if the maps were installed to a memory card.
    • See the video below for steps to properly insert the memory card
See Troubleshooting Wireless Updates on the Camper/RV 785, dezl 780, dezlCam 785, or Overlander if you encounter issues updating via Wi-Fi.
