Navigational Avoidances on Automotive Devices
Garmin devices have an Avoidance menu where you can select various options that will adjust how your device routes you. Items with a check mark beside them will be avoided whenever possible.
To locate the Avoidance menu:1
  1. Touch Tools
    • Skip this step on some devices
  2. Touch Settings
  3. Touch Navigation
  4. Touch Avoidances
    • Touch Enabled for some devices
  5. Touch the desired Avoidance to enable it
  6. Touch Save or OK
Repeat the steps above to disable the checked Avoidance.
Available avoidances:
  • U-Turns – Avoids calculating routes that require a U-turn
  • Highways or Motorways – Avoids highways, interstates, freeways, motorways, and other major routes
  • Toll Roads or Tolls and Fees – Avoids toll roads and certain specified congestion zones
  • Traffic – Avoids traffic if a quicker route is available
    • Requires a Traffic Receiver and subscription (not available on all models)1
  • Ferries – Avoids routes that require a ferry crossing
  • Carpool Lanes or Car Share Lanes – Avoids lanes designated specifically for carpooling
  • Unpaved Roads – avoids unpaved roads (gravel, dirt, etc.)
Note that devices will only avoid selected items when it is possible. For example, if you have U-Turns selected as an avoidance the device may still direct you to make a U-Turn if an alternate route is not available.
1Disabling the traffic avoidance does not disable traffic alerts from appearing on the device; however, it will not take the reported traffic incident into account when calculating routes.
