Du ser på en artikkel som ikke er tilgjengelig på det valgte språket ditt. Du kan velge et annet nedenfor.
When does my GDL 50, GDL 51, and GDL 52 go into Power Safe Mode?
The battery saver feature on the GDL®50, GDL®51, and GDL®52 will turn off the unit when external power is removed if all three of the following conditions are true:
Ground Speed less than 20kts or No GPS fix.
No Connext connection.
Running on battery only.
Once these three conditions are met, the unit will power off after two minutes.
