D2 Mach 1
Descent Mk2 Series
Enduro Series
epix (Gen 2) Series
fenix 6 Series (requires software update)
fenix 7 Series
Forerunner 955/955 Solar
Forerunner 965
MARQ Collection (requires software update)
MARQ Collection (Gen 2)
tactix 7 Series
tactix Delta Series (requires software update)
Setting up ClimbPro Alerts on a Garmin Watch
ClimbPro alerts allow you to customize when you will be alerted for upcoming climbs when navigating a course in compatible activities.
Enter the activity list
Select an activity.
Hold UP/MENU to enter the activity menu.
Select (Activity) Settings.
Select ClimbPro.
ClimbPro Status must be set to When Navigating for ClimbPro and alerts to function.
Select Alert.
Setup Alerts:
Select At Start of Climb for alerts at the beginning of a climb.
Select Distance to set a distance.
Your ClimbPro and Alert settings will be saved when you exit the menu. You will now be alerted based on your settings while using ClimbPro. For more information on ClimbPro, refer to your owner's manual.
