inReach Mini 2 Firmware Update Release Notes
The inReach Mini 2 firmware updates provide inReach satellite communicators with new features and capabilities. The inReach Mini 2 can receive firmware updates thru the Garmin Express application or the Garmin Explore app. For more information on updating the inReach Mini 2 firmware, see - Updating the Software on Your inReach Mini 2.
v3.17 March 29th, 2022
  • Improved behavior with large numbers of courses
  • Improved "Share With" MapShare flow, now skips contact selection
  • Implemented assorted TracBack fixes and improvements
  • Addressed some layout issues
  • Updated "Check for Messages" to be more similar to other glances
  • Changed "Display" settings to "Backlight" settings
  • Added map pick functionality
  • Added dynamic wind speed icons for marine forecasts
  • Added weather additional charges prompt
  • Updated mark waypoint icons in main menu
  • Updated order of marine and basic/premium weather
  • Updated preset icons to indicate message is outgoing
  • Implemented tap of power button turn on backlight
  • Improve BLE pairing to Garmin Pilot App
  • Fixed autocomplete issues for contacts with emojis in the name
  • Fixed emojis being cut off on some pages
  • Fixed issue which could result in user getting stuck pairing flow
  • Corrected backlight from timing out during startup
  • Fixed issue preventing power button from operating on test device page
  • Updated language around check for plan updates
  • Added timestamp to activities exported to GPX
  • Fixed potential shutdown when viewing map action menu while arriving at destination
  • Improved validation of points before including them in exported GPX files
  • Fixed defect which could cause power menu to be inaccessible
v3.10 February 2nd, 2022
  • Added a loading screen when generating TracBack preview
  • Updated confirmation dialog appearance
  • Updated alert dialog appearance
  • Added message icons to the map
  • Reduced amount of time required to register a button hold
  • Added percentage to battery icon when in thermal warning mode
  • Moved presets to dedicated main menu item
  • Disabled auto zoom on map
  • Added error messages to indicate when a waypoint cannot be created
  • Added support for file-based configuration
  • Reduced frequency at which device prompted to wait for GPS or send message anyway
  • Updated appearance of About page
  • Added support for GPX export
  • Added track points to the map
  • Added ability to save an address from message thread
  • Added ability to create contacts on device
