VIRB videos split into multiple recordings
While recording, the VIRB may split video recordings into several smaller files on the device. This is due to a limitation associated with each recording format.
For example, while recording in 1080p the VIRB will automatically save one recording and start another after approximately 24 minutes. This time limit will vary depending on the selected recording format.
VIRB Edit allows you to combine and edit any of the smaller recordings as desired.
