Vector 3 and Vector 3S Status LED Lights
The Vector 3 and Vector 3S system features status LEDs on the end of the spindle located on the inside of each crank arm.*
LED Light StatusPedal StatusTroubleshooting Tips
1 red flashThe Vector system is active and working properly.None
3 green flashes every 10 secondsThe pedal is searching for the other pedal.Confirm opposite pedal has good batteries and pedal is in working condition
Alternating red and green flashesA software update is in progress.Wait for software update to finish installing
20 green flashes
The software update was successful.
The pedals found each other successfully and are up to date.
None
20 red flashes
The software update failed.
The left pedal could not find the right pedal or failed to update the right pedal.
Reapply software update
*Vector 3S will only have a status LED on the left pedal.
*The Vector 3 and Vector 3S system does not flash an LED when the batteries are low. This is done to save battery life.
