Change Home Location on StreetPilot Devices
The Go Home feature allows the device to quickly create a route to the location set as Home. In some cases, you may need to change the home location.
To view the directions on how to change the home location on your StreetPilot, click your device listed below:
StreetPilot 2600 series
To change the Home waypoint:
  1. Press the FIND key
  2. Touch the Waypoints icon
  3. Find and select your Home waypoint
  4. When the Waypoint Review page appears, touch Delete
  5. Touch Yes to confirm
  6. Press down and hold the Menu key from your StreetPilot or remote control
  7. From the Route Menu page, touch Set Home Waypoint
  8. Select the desired option for setting a new home location
The home location has now been changed. Repeat these steps as desired. To route home in the future, simply press your StreetPilot's FIND key two times. A window asking you to verify that you want to route home will appear. Select Yes, and your StreetPilot will then direct you to your home location.
Back to top
StreetPilot 2700, 2800, and 7000 series
To change Home location:
  1. Touch Where To?
  2. Touch My Locations
  3. Touch Favorites
  4. Touch the favorite named Home
  5. Touch Advanced
  6. Touch Edit Favorite
  7. Touch Delete and confirm by touching Yes
  8. Touch the back button until you exit the My Locations menu
  9. Touch the Go Home button in the bottom-right
  10. Select the desired option for setting a new home location
Back to top
StreetPilot c300
To change the Home location:
  1. Touch Where to? on the main menu
  3. Touch Set Home
  4. Touch the desired option for selecting the new home location
Back to top
StreetPilot c500
  2. Touch Favorites
  3. Touch the favorite named HOME
  4. Touch Edit
  5. Touch Delete then confirm by touching Yes
  6. Touch the back button to exit the Favorites list
  7. Touch Go Home
  8. Touch the desired option for selecting the new home location
Back to top
StreetPilot i2, i3, and i5
  1. Use the Wheel to select Where To? (press the Wheel to select)
  2. Select My Favorites
  3. Select the Favorite named Home
  4. Select Delete
  5. Select Yes
  6. Press the Back button until you see the Where To? page
  7. Select Go Home
  8. Select Yes
  9. Enter the desired address
  10. When you see the message “Your Home Location has been saved to My Favorites” press the wheel to confirm
Back to top
