Garmin Connect App: Sharing Your Garmin Connect Account
Starting in November of 2022 Garmin enabled a feature in Garmin Connect that will allow you to share your Garmin Connect account with another user using the Garmin Connect app.  Sharing an account allows friends or family members to have full, read only, access to parts of your Garmin Connect account.  To share your account, you will need to first add another Garmin Connect user as a Connection.  For more information about adding Connections in Garmin Connect see FAQ: Add and Remove Connections in Garmin Connect
To learn more about sharing your Garmin Connect account, choose a topic below.
How do I Share My Account with Another Garmin Connect User?
To enable read only access to another Garmin Connect user:
  1. Open the Garmin Connect app.
  2. Open the menu.
    • Android: Select Three blue hotizontal lines (upper left)
    • iOS: Select More (lower right)
  3. Select Settings.
  4. Select Profile & Privacy.
  5. Select Authorized Viewers.
  6. Select Add Authorized Viewer.
  7. Follow onscreen prompts to search and add Connections or send a request to a current Connection.
How do I Stop Sharing My Account?
  2. Open the menu.
  3. Select Settings.
  6. Select the authorized viewer you would like to remove access from.
  7. Select Revoke Access
  8. From pop up window, select Revoke Access.
What Data is Visible If I Share My Garmin Connect Account?
The following data is shared with authorized viewers of your Garmin Connect account:
  • Activity and wellness data
  • User profile information
  • Training and planning data
  • Reports
What Data is Not Visible When Sharing My Garmin Connect Account?
Not all parts of an account are visible to an authorized viewer. Social related features that display another user’s account are not visible to authorized viewers. Additional information not visible includes:
  • Newsfeed
  • Diving
  • Groups
  • Challenges
  • Golf leaderboard and scorecards
  • Segments
  • Courses
  • Badges
  • Quickdraw
Viewing A Connection’s Garmin Connect Account as an Authorized Viewer
If you have been sent, and accepted, an account sharing request you can view the account by doing the following:
  2. Open the menu.
  3. Select Settings.
  6. Choose the account you would like to view.
  7. Select View Account.
  8. Acknowledge redirect pop up window by selecting Continue
You will be redirected to a web view of the chosen account.
How Many Account Sharing Requests Can I Send?
You can establish a maximum of 20 account sharing connections with other Garmin Connect users.
