Garmin Golf App Troubleshooting
NOTE: The following instructions are only for devices that pair directly through the Garmin Golf app and is not applicable for devices pairing through the Garmin Connect app. For information on our other devices that work with the Garmin Golf app, see - Devices Compatible with Garmin Golf App
The following devices will pair directly through Garmin Golf:
  • Approach G12
  • Approach G80
  • Approach R10
  • Approach S12
  • Approach S40
  • Approach S42
  • Approach S62
  • Approach Z82
  • MARQ Golfer
Troubleshooting Pairing and Syncing Issues With the Garmin Golf App
If you are having problems syncing your device with the Garmin Golf app then this article will walk you through various steps to resolve the issue.
My Garmin Is Showing as Connected, but I Am Unable to Sync
Try each step followed by checking to see if the problem is resolved:
NOTE: Make sure that the Bluetooth setting on your Garmin device is not turned off. This will result in your device not connecting to the app to sync your data. Refer to your owner's manual to check this setting.
  1. Close the Garmin Golf app, then reopen it.
  2. Power the Garmin device off and then power it back on.
Pairing Failed During Setup
Try the following steps if you are receiving a Pairing Failed message.
  • Choose Retry. Sometimes attempting the process a second time will finish the pairing process.
  • Reboot the Garmin device by powering it off and then powering it back on.
  • Reboot the smartphone by powering it off and then powering back on.
  • Try signing out and then back into the Garmin Golf app.
  • When prompted from the phone, make sure that you are entering the six-digit code displayed on your Garmin device into your smartphone. Not entering this code, or entering the wrong code, will result in a Pairing Failed message.
Device Not Found by Garmin Golf
If you are attempting to add your Garmin device to the Garmin Golf app and the app is not finding your device, review the following common solutions that may solve your problem.
  • Make sure that pairing mode is enabled on your Garmin device. Turning on pairing mode will trigger a Bluetooth beacon signal that the Garmin Golf app will look for. Access Settings and then Bluetooth or Phone options to enable pairing mode on your Garmin device. The location of this setting can vary, consult your owner's manualfor specific instructions.
  • Turn the Bluetooth setting on your smartphone off and then back on. Cycling this setting on your smartphone can resolve some pairing issues.
  • Power off and then power on your Garmin device. If you have a Garmin device that does not feature a button, use the charging cable and plug it into external power. The device will reboot automatically when you connect it to an external power source.
  • If the Garmin device has been previously paired to the smartphone but is no longer able to connect, remove the previous pairing from both the Garmin Golf app as well as the phone's Bluetooth Settings.
Removing a Device From Garmin Golf
Android
  1. Open the Garmin Golf app.
  2. Select Three Horizontal Lines Icon.
  3. Select Garmin Devices.
  4. Touch and hold the image of the Garmin device that you want to remove.
    NOTE: You will be taken to the Garmin Connect app to complete the process if you own a device that pairs to Garmin Connect then the Golf app. For instructions, see - Instructions to Remove and Add a Device in the Garmin Connect App.
  5. Select Remove Device from the pop-up box.
  6. Tap Remove.
    NOTE:
    The device may still be paired under the Bluetooth settings of the smartphone. You may have to remove the device from these settings as well. Settings vary based on the model of your phone. Consult your owner's manual for specific steps.
The device is now removed from the Garmin Golf app and the smartphone's Bluetooth settings.
iOS
  2. Select More.
  4. Select the image of the Garmin device that you want to remove.
  5. Tap Golf App Three Orange Dots.
  6. Select Remove Device.
    NOTE: You will be taken to the Garmin Connect app to complete the process if you own a device that pairs directly with the Garmin Connect app. For instructions, see - Instructions to Remove and Add a Device in the Garmin Connect App.
  7. Tap Remove.
    NOTE: The device may still be paired under the Bluetooth settings of the smartphone. You may have to remove the device from these settings as well. Settings vary based on the model of your phone. Consult your phone's owner's manual for specific steps.
My Scorecards Show in Garmin Connect, but Do Not Show in Garmin Golf
Items in the Garmin Connect sync queue will typically be cleared out automatically whenever you sync your device, but if your scorecards are not showing in the Garmin Golf app it may be necessary to manually clear out the sync queue.
Removing Items From the Sync Queue in Garmin Connect Web
  1. Go to Garmin Connectfrom a personal computer.
  2. Sign in to your account.
  3. Select Image of Watch Icon in the top right corner.
  4. Select the number in the blue circle (to the right of the device name).
  5. Select X next to the item you wish to remove from the sync queue, and then Remove.
  6. Repeat step 5 for any additional items you wish to remove from the sync queue.
If you continue to have an issue after trying the above steps, contact Garmin Product Support for further assistance.
