Troubleshooting an Issue between a Garmin Automotive Device and a Bluetooth Headset
If you experience any issues with pairing a Bluetooth-enabled headset/helmet to your automotive device, or encounter issues while the two are connected, we suggest troubleshooting in the following order:
  1. Software Update
  2. Clear Pairing History
  3. Check Compatibility
  4. Check for Supported Audio Types
  5. Alternate Pairing Modes
Software Update
  • It is recommended for your mobile phone and headset to have the latest software as well. Consult your phone and headset owner's manuals for guidance on how to update.
Back to top
Clearing the pairing history on the automotive device and the phone will establish a new Bluetooth session between the devices. Step-by-step instructions for clearing the pairing history can be found below:
1. Touch the dezl 78x settings gear transparent v2 Settings icon
dezl 78x - main page - settings
2. Touch Bluetooth
Android - settings menu - Bluetooth
3. Next to the device you wish to delete, touch the Android settings gear gear icon
Android - Bluetooth - device options
4. Touch Forget
Android - Bluetooth - forget device
5. Touch OK
Android - Bluetooth - confirm forget
  • If the headset is also paired to your phone, we recommend clearing the pairing history for this device on your phone as well.
Back to top
Check Compatibility
Back to top
Your device can receive the following audio prompts through a Bluetooth headset:
  • Navigation Prompts - During navigation, when an instruction such as "Turn left in 500 feet" plays through the device, this prompt will be played in your headset.
  • Phone Calls - As long as your phone and headset are both paired to the device, whenever you receive a phone call, the phone audio will be played through the headset.
Back to top
  • Bluetooth headsets/helmets (especially those designed for motorcycle usage) will often have multiple Bluetooth pairing modes. These are designed to give the Bluetooth accessory flexibility for different uses (phone, navigation, music, etc.). It may be necessary to try the other pairing modes offered by your headset to find one that works best with your Garmin device.
  • The owner’s manual for your Bluetooth headset should include instructions on how to use these alternative pairing modes if it applies to your Bluetooth headset.
Back to top
If the problem persists beyond this troubleshooting, contact Garmin Product Support.
