Je bekijkt een artikel dat niet beschikbaar is in de geselecteerde taal. Je kunt hieronder een andere taal kiezen.
Steps to Link Your Garmin Connect Account with Strava
Linking your Garmin Connect™ account to your Strava account allows for activities uploaded to Garmin Connect to automatically show up in Strava. You must link the two accounts through Garmin Connect following the steps further down in this FAQ.
Once linked, the following data will be synced:
  • Activities uploaded to Garmin Connect
    • Activities created with Strava will not sync to Garmin Connect
  • Starred Strava courses
  • Starred Strava segments
Previous activities in your Garmin Connect account will sync to Strava, as will future activities which are uploaded to Garmin Connect. Automatic historical upload only applies to the first time the accounts are linked. Any subsequent connections will require history recorded while Garmin Connect and Strava are not linked to be manually uploaded to Strava.
Steps To Link Strava and Garmin Connect Using Garmin Connect App
Ensure that you have downloaded the Strava app on your phone, have created a Strava account, and are logged in.
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Settings.
  4. Select Connected Apps.
  5. Select Strava.
  6. Select Agree.
  7. Select Authorize.
It can take several minutes before the initial sync is complete.
If you receive an error when trying to sign in to Strava using the "Log in using Google", you will need to visit http://www.strava.com/upload/device. You can find the Garmin option to authorize your link with Strava.
Steps To Link Strava and Garmin Connect Using Garmin Connect Web
NOTE: These steps require that you have a segment compatible device added to your Garmin Connect account. For details, see - What Garmin Devices Are Compatible With Segments?.
  1. From a web browser, sign into your Garmin Connect account.
  2. Select Training and Planning from the navigation bar on the left.
  3. Select Segments.
    • To access Strava segments in Garmin Connect a Strava segment compatible device will need to be associated with the account.
  4. Select Switch to Strava Segments.
  5. Authorize Strava segments in Garmin Connect.
You can also tie your Garmin Connect account to your Strava account from Strava following the instructions on this Strava Support FAQ: Automatically Sync Strava with Garmin Connect.
Verwant
