Which Type of Axle Do I Have on My Tacx Trainer?
Tacx direct-drive trainers come in two different axle types:
Type 1: 6 mm or 9 mm internal diameter axle hole suitable for a quick-release skewer.  Adapters allow for a thru-axle bike to be installed onto the trainer using a quick-release skewer.
Type 2:  12 mm internal diameter axle hole suitable for using a bike's thru-axle. Adapters allow the use of a quick-release skewer as well.
How do I determine which type of axle my trainer has?
Type 1 trainers:
  • NEO Smart
  • NEO 2 Smart
  • FLUX Smart
  • FLUX S Smart*
  • FLUX 2 Smart*
Type 2 trainers:
  • NEO 2T
  • FLUX S Smart*
  • FLUX 2 Smart*
*FLUX S and FLUX 2 trainers have been manufactured using both Type 1 and Type 2 axles.  You can choose one of the following identification methods to determine which trainer type you have:
  • Identify the part number on the cassette body installed on the trainer out of the box:
    • Type 1: T2805.01 (S)
    • Type 2: T2875-01
  • Measure the inside diameter of the trainer axle with the cassette body removed using a caliper tool (pictured below)
    • Type 1: 6mm or 9mm
    • Type 2: 12mm
tacxmeasurepic
Which Cassette Body do I need for my trainer?
Direct-drive trainers come with a SHIMANO/SRAM cassette body out of the box.  If you need a replacement or different cassette body, below are part numbers available for purchase:
Description
Service Part Number
SHIMANO/SRAM Cassette Body (Type 1)S0012
SHIMANO/SRAM Cassette Body (Type 2) - coming soon to Garmin.comS0050
Tacx Campagnolo Cassette Body (Type 1)T2805.51
Tacx Campagnolo Cassette Body (Type 2)T2875.51
Tacx SRAM XD-R Cassette Body (Type 1)T2805.81
Tacx SRAM XD-R Cassette Body (Type 2)T2875.76
