Replacement Locking Collars for Garmin® Marine Devices
Newer Garmin® cables do not have the locking collars factory-installed; this allows for easier installation when routing the cables through and behind cabinetry. The two-piece locking collar is attached to the connector. Double-check, the box for the included split locking collar but if lost or if a replacement is needed, see the below list for part numbers. Refer to Marine Cable Locking Collar / Split Connector Installation for instructions.
11mm Cables
Threaded Locking Collar - 010-11170-01
2-pin power cable GPSMAP® 4xxx and GPSMAP® 5xxx series (verify threaded)
8-pin power cable (some ECHOMAP™s and GPSMAP®)
Power cable - GSD™ 24, GSD™ 25, and GSD™ 26, GCV™ 10, GCV™ 20
8-pin transducer cable
12-pin transducer cable
Small Marine Network cable
Power cable - AIS 300 and 600
GHC™ 101 , GHC™ 20, and GHC™ 50
GHP™ 10 ECU connections2
GHP™ 12 ECU connections
All Garmin Marine Radar systems1
1 check for threaded or quarter turn port. Depending on the manufacture date, all Garmin radars could contain a threaded or a quarter-turn connector. Confirm which collar is needed before placing an order
2 This only applies to GHP 10 ECUs packaged in the Reactor 40 Core packs
14.5mm Cables
Threaded Locking Collar - 010-11170-02
19-pin power cable GPSMAP® 7x0 series
NMEA 0183 cable GPSMAP 4xxx 5xxx, 6xxx, 7xxx, and 8xxx (verify thread on the GPSMAP 4xxx - 5xxx series)
18mm Cables
Threaded Locking Collar - 010-11170-00
Large Network Cables (RJ 45) - including Panoptix series transducers and sonar modules
LVS32 LiveScope Transducer
Video cable GPSMAP 4xxx, 5xxx, 6xxx, GPSMAP 7xxx (verify thread on the GPSMAP 4xxx-5xxx series)
