Wyświetlany artykuł nie jest dostępny w ustawionym obecnie języku. Możesz wybrać inny język poniżej.
Managing Audio Content on My Watch Using Garmin Express
Music, playlists, audiobooks, and podcasts from your computer can be installed to a Garmin® music watch using the Garmin Express™ software program.
NOTE: Protected AAC audio files cannot be transferred to a watch without removing the Digital Rights Management (DRM) designation from the file. Files that have been downloaded from certain music subscription services may also be protected which can prevent them from being compatible. For assistance or questions related to protected audio files refer to your music provider.
For detailed instructions on this process, select your operating system below:
Windows® Computers
The process of adding content to a watch can be broken down into three steps. Select each section to expand and view information on completing each step:
Step 1: Organize Your Music Library On Your Computer
Use your preferred media management program (Windows Media Player®, iTunes®, etc.) to create and edit playlists.
If using iTunes as your media management program, the following Apple® support articles provide helpful instructions for setting up iTunes and managing your music library on your Windows computer:
Under "My Music", select an audio file category, such as Songs, Playlists, or Podcasts.
If your content is not automatically displayed make sure that Garmin Express is up-to-date and that you have selected the folder that contains your files.
By default, Garmin Express will search for files in the Music folder on your computer, but you can browse for other folders including other connected hard drives by selecting next to "My Music."
If your music still is not displayed, select and then Refresh Library.
If you use the iTunes® program to manage your library you will see "iTunes Library" and instead of "My Music" and .
Select the checkboxes for the audio files you wish to add and then select Send to Device.
Removing Content From the Watch:
Under My Music select an audio file category, such as Songs or Podcasts.
Select the checkboxes for the audio files you wish to remove and select Remove.
If you select a Playlist to be removed, only the playlist file will be removed from the device.
The songs in the playlist will still be on the device and would need to be removed from the Songs category if desired.
Media files must be stored on the hard drive of the computer. External drives and Cloud Storage (Home Network, Google Drive™, etc.) are not detected by Garmin Express.
Mac® Computers
