Wyświetlany artykuł nie jest dostępny w ustawionym obecnie języku. Możesz wybrać inny język poniżej.
Searching Near a Different Location on the Tread®
By default, your device searches near your current location. If your device cannot find the destination you have entered, it may be searching in the wrong area.
To Search Near a Different Location:
1. Touch Search
2. Touch the Searching Near field
3. Touch the preferred option in the list (scroll up or down to see all options)
Available Options:
Where I Am Now Searches near your current location (this is the default setting).
A Different City Searches near a specific city you enter.
Recent Destination Searches near a recently found location listed in the device's Recent menu.
Saved Place Searches near a location from the device's Saved menu.
My Active Route1 Searches along your currently active route.
My Destination1 Searches along the currently active route, but starts near the destination and works backward along the route.
To begin searching near your current location once again, simply return to the main menu to restore the default setting.
1These options are only available when you have entered a destination and your device is currently navigating an active route.
If the errors "No Matches Found" or "Cannot Find Search Results" continue to appear when searching for a destination, try the following steps in order:
