Está a visualizar um artigo que não está disponível no idioma atual selecionado. Pode escolher outro idioma abaixo.
Updating Garmin Dash Cam Software using Garmin Express
The Garmin Express™ software can be used to update Garmin Dash Cam™ driving recorders. See How Do I Install Garmin Express?
You may also use the Garmin Drive app to install software updates on compatible dash cams.
NOTE: Following the steps below can cause the update not to install properly in Garmin Express in rare cases on the Garmin Dash Cam 45, 46, 54, 55, 56, 65W, or 66W. See Garmin Dash Cam Software won't Install Following Garmin Express Instructions if you're having problems.
To Update Software Using Garmin Express:
1. Connect your device to the computer
2. Open Garmin Express
3. Choose or Add a device
4. Click Install
Garmin Express will now install the software updates to your Garmin Dash Cam.
Troubleshooting a Connection Issue with a Garmin Dash Cam and Garmin Express
There may be an issue if the dash cam could not completely boot up.  This could be caused by:
Relacionado
