My Fusion Marine Stereo Will Not Turn On
There are 2 power wires and 1 ground wire that need to be connected for your Fusion marine stereo to operate correctly.
Both the red and yellow wires need to be connected to 12V and the black wire to ground/battery negative.
The yellow power wire is the high current supply wire. This needs to be connected to your battery using a cable suitable for carrying at least 15 Amps.
The red power wire is a switched input. When 12V is connected to this wire the marine stereo can operate. When disconnected, the stereo will shut down and remain off.
The red wire may also be connected together with the yellow wire if you are supplying power through a switch panel capable of 15A, or if a battery isolator is used to disconnect the battery when not in use.
The yellow +12V wire in some stereos provides power to the memory of the unit for presets etc. This only applies to Fusion's MS-CD80 as Fusion's 600 and 200 Series stereos are designed to save all settings when power is removed.
