Está a visualizar um artigo que não está disponível no idioma atual selecionado. Pode escolher outro idioma abaixo.
Replacement Motorcycle Mounting Kit
zumo devices come packaged with a motorcycle mount1 and a Ram Mounting Kit. If you need to replace your mount or purchase an additional one, select your device's link below for the available accessories.
Garmin® strongly recommends having an experienced installer with the proper knowledge of electrical systems install the device. Incorrectly wiring the power cable can result in damage to the vehicle or the battery and can cause bodily injury.
See the Important Safety and Product Information guide in the product box for product warnings and other important information. Installation instructions can be found in your device's Owner's Manual.
- zumo 300 series accessories
- zumo 590 accessories
- zumo 595 accessories
- zumo XT accessories
- zumo XT2 accessories
Note: If upgrading to a new zumo, the RAM mount will remain the same, but each device series will use a different motorcycle mount.
1The nüvi® 500 and zumo 220, zumo 550, zumo 660, and zumo 665 motorcycle mount has been discontinued.
