Selectați produsul dvs. pentru a confirma că aceste informații vi se aplică
Vizualizaţi un articol care nu este disponibil în limba curentă selectată. Puteţi alege o altă limbă mai jos.
Using Map Manager on Edge Cycling Computers
Compatible Edge® cycling computers feature the ability to update, install, and remove maps directly on the Edge via Wi-Fi®, in addition to on Garmin Express™
Compatible Edge Cycling Computers
NOTE: This feature requires the latest software. Refer to this FAQ for updating software.
  • Edge® 840 | Edge® 840 Solar
  • Edge® 1040 | Edge® 1040 Solar
  • Edge® 1050
Add a Wi-Fi Network
On the Edge:
  1. Select the menu.
  2. Select Connected Features.
  3. Select Wi-Fi.
  4. Select Add Network.
On the Garmin Connect App:
  1. Select More.
  2. Select Garmin Devices.
  3. Select Wi-Fi Networks.
  4. Select Add a Network.
Manage Maps
Update or Remove Existing Maps
Existing maps will occasionally require updates to ensure map details are accurate, or need to be removed to create space for other regions.
  1. Select the menu.
  2. Select System.
  3. Select Map Manager.
  4. Select Cycling Maps or Other Maps.
  5. Select Download Update to update to current version.
  6. To Remove Map, Select (3 dots) > Remove
Add New Maps
  1. Select the menu.
  2. Select System.
  4. Select White plus icon in blue box .
  5. Select a region.
  6. Select Download Update
The download will occur in the background, and may pause if your device is out of Wi-Fi range, the battery is low, or you are in an activity. Speeds for the download can vary based on internet speeds and the number of other connected devices on the Wi-Fi network. Garmin Express™ can sometimes provide a more stable connection if your Wi-Fi signal is weak.
You will see the status of your download in the menu bar:
Progress bar with 81 percent loaded
map manager download is paused
What Map Regions are Available?
NOTE: Refer to this FAQ for information on which maps will come pre-loaded on your Edge computer.
Effective May 7. 2025, Garmin Cycle Maps for Edge® cycling computers and Garmin® watches are being discontinued. The same mapping content will now be included in our TopoActive maps and can be purchased or downloaded on compatible devices. For more information on Garmin TopoActive maps, see Current Version of TopoActive Maps. To update the maps on your Edge, refer to Verifying the Maps Installed on a Garmin Edge Device or your owner's manual.
TopoActive Europecyclemap Europe coverage
TopoActive North America Cyclemap North america coverage
TopoActive South America CM South America coverage
TopoActive Africa CM africa coverage
TopoActive Australia & New Zealand CM Australia new Zealand
TopoActive China Mainland CMChina coverage
TopoActive Hong Kong  CM hong kong coverage
TopoActive Indonesia, Thailand CM Indonesia thailand coverage
TopoActive Japan CM Japan coverage
TopoActive Korea CM Korea coverage
TopoActive Middle East Cm middle east coverage
TopoActive SGMYVNPH (Singapore, Malaysia, Brunei, Vietnam, and Philippines) CM SEA coverage
TopoActive Taiwan CM Taiwan coverage
