Pairing Forerunner 630 with Garmin Connect Mobile
When paired with a Forerunner 630, the Garmin Connect Mobile app can wirelessly upload and share fitness data with the Garmin Connect website. The Forerunner will only pair with compatible mobile devices that support Bluetooth Smart (BLE) wireless technology. Use the following instructions to pair your Forerunner 630 with Garmin Connect Mobile:
iOS:
- Place the iOS device within 10 ft. (3 m) of the Forerunner 630.
- Ensure that Bluetooth is enabled on the iOS device (see iOS device manual for details).
- On the iOS device, open the Garmin Connect Mobile application.
- Touch the 'More' icon in the lower right corner.
- Touch 'Garmin Devices'.
- Touch 'Add Device'
- Touch 'All Devices'
- Touch 'Forerunner 630.
- Complete the Personal Information if requested. This allows the Forerunner 630 to assign personalized goals and learn your activity level.
- Touch 'Next'.
- On the Forerunner 630, access the Menu.
- Touch 'Settings'.
- Touch 'Bluetooth'.
- Touch 'Pair Smartphone'.
- Touch 'Start' on the application.
- Touch 'Yes' after verifying the passkeys match.
- Touch your choice for Activity Tracking.
- Touch 'Done'.
Android:
- Place the Android device within 10 ft. (3 m) of the Forerunner 630.
- Ensure that Bluetooth is enabled on the Android device (see Android device manual for details).
- On the Android device, open the Garmin Connect Mobile application.
- Touch the menu button (≡) located in the upper-left corner.
- Touch '+' in the upper-right corner.
- Touch 'All Devices'.
- Touch 'Forerunner 630'.
- Touch 'Settings'.
- On the application, touch 'Search for Device'
- Touch your choice for Activity Tracking, if prompted.
- Touch 'Ok' when the devices are paired.
Windows:
- Touch + icon on ‘Devices’ screen.
- Touch device series.
- Touch the Model of the device.
- With the device in Pairing Mode, touch ‘Add Device’.
- Once discovered, Touch the device to pair.
- When requested, type or verify the PIN displayed on device and touch ‘Allow’.
- After connection is successful, touch ‘Close’ and continue.
- If connection fails, touch ‘Close’ and troubleshoot pairing.
- If permissions are requested, touch ‘Yes’.
- Wait for Setup and initial Sync to complete.
- Once pairing is complete, touch ‘Done’.
- Device is now Paired and Ready
You have now paired the Garmin Connect Mobile application with your Forerunner 630, and the device can now sync.
