Getting Started With Fltplan Go
FltPlan® Go Flight planning services, the application that works in conjunction with FltPlan.com, is available on iOS (iPad/iPhone) and Android. Simply go to the iOS App Store, or the Google Play Store, type "FltPlan Go" in the search box, and download the application.
FltPlan Go is free and can be downloaded on an unlimited number of devices.
Information across multiple devices can be synced with FltPlan.com, so long as the same login information is used, and you are within range of Wi-Fi.
FltPlan Go can be used while offline. Downloading charts, updating weather, filing a flight plan, and some other features require an internet connection. However, once the charts are downloaded and flight plan filed, these mapping features work offline for inflight use.
FltPlan Go for iPad requires iOS 12 and later to install. FltPlan Go for Android requires OS 6.0 and later to install. For capacity, we recommend 128GB and a Wi-Fi + Cellular model. If you get a Wi-Fi only model, you will need an external GPS/ADS-B device.
To stay signed in, tap the Sign In button in the top right corner on the FltPlan.com, Maps, or NavLogs tab. Enter your Username and Password, then tap Sign In.
