Software Updates for Alpha LTE Collar
The Alpha® LTE collars can have their software updated via the Alpha® app or Garmin Express™ software. The simplest method is to let the Alpha app provide the software update automatically to the Alpha LTE collar. You can also initiate this manually through the Alpha app if an update is available and has not yet been sent to the collar. You can check the software status of the Alpha LTE collar from the Alpha app. You can also manually update the software on the collar using the Garmin Express software.
Updating Software Using Alpha LTE App
To update the collar using the Garmin Alpha app follow these instructions:
  1. In the Alpha app, select Devices
  2. Select the Alpha LTE collar
  3. Select Software Update
  4. Follow the instructions listed for Update with Garmin Alpha
null
