Garmin Automotive Device isn't Acquiring Satellites
The environment you operate your device in may affect satellite acquisition. Take your device out of parking garages and away from tall buildings and trees.
Data is gathered as you use your device. This helps them acquire satellites quickly at the start of each use. The device should be able to acquire satellites in a minute or less if used daily. Using the device outdoors with a clear view of the entire sky is recommended to acquire satellites.
The Following Video Discusses Charging your Device and Acquiring Satellites:
Factors that May Cause the Device to be Unable to Acquire Satellites:
It may take longer than normal to acquire satellites the first time you power your device
This should not take more than 3-5 minutes if the device has a clear view of the sky
- The device will not acquire satellites if the GPS Simulator is enabled
- Reference your device's Owner's Manual on our Support Center for steps to verify the GPS Simulator is disabled
The device may not acquire satellites properly without a clear view of the sky
Mount the device on the windshield or dashboard for the best satellite acquisition
It may take 3-5 minutes to acquire satellites if your device has not been used for more than a month
The device may not acquire satellites indoors
Even standing next to a window indoors will block a majority of the sky which is needed for a device to acquire a satellite signal
It may take 3-5 minutes to acquire satellites if your device has traveled over 500 miles while turned off or not tracking your travel
Your device may not be able to acquire satellites if your vehicle has a protective coating on its windshield or electronic devices that may interfere with the device receiving a signal.
Some vehicles are equipped with special windshields that may contain metal in the glass (metal oxide) that prevents the GPS device from having a clear line of sight to the satellites
Windshields with solar ray glass, solar tint, heated, or heat-reflective windshields and insulated or Insta-Clear glass may also affect satellite acquisition
Try taking the device outside of the vehicle with a clear view of the sky for 3-5 minutes so that the device can acquire satellites if you suspect this to be an issue
If your device loses satellites once moved back into your vehicle, this is most likely the reason
If your device is still having trouble acquiring satellites, ensure it has the latest version of operating software by following the steps in the Software section under your device in Support Center. Allow the device to acquire satellites outdoors in a stationary position with a clear view of the sky after you update. A master reset may be necessary if the issue continues.
To perform a master reset
Note: A master reset will erase all favorites and will restore your device to the default factory settings. See Backing up, Restoring, or Transferring Saved Data on Garmin Automotive Devices for instructions to back up your data. Although the master reset will erase all saved favorites, any loaded custom points of interest will remain intact on the device.
- Start with the device turned off and unplugged from power
- To verify the device is powered off and not in standby mode, press and hold down the power button until prompted to turn off the device
- Power on the device
- When the first copyright screen appears press and hold the lower right-hand corner of the display portion of the touchscreen
- Remove your finger from the touchscreen when "Erase all user data?" appears
- Touch Yes
Another Option to Perform a Master Reset:
- Touch View Map
- Touch the Speed icon
- Touch and hold the speedometer for approximately 5 seconds
- Release your touch when the Diagnostics Page displays
- Touch Clear all user data
- Touch Yes when prompted to "Erase all user data?"
The device will now reset. Follow the on-screen prompts and then place your device in an area with a clear view of the sky until it acquires satellites.
Note: A master reset may erase the data used to locate satellites. Your device may take 3-5 minutes to acquire a satellite signal while outdoors after updating the software or performing a master reset.
