Garmin Dash Cam 45, Garmin Dash Cam 54, Garmin Dash Cam 55, or Garmin Dash Cam 65W Not Recording or Missing Video
Follow the steps below if saved or unsaved footage cannot be found on your Garmin Dash Cam device, the VIRB Mobile App, or the device's SD card:
- Ensure the device is recording video
- Check Event Detection settings
- Check SD card compatibility
- Ensure the device and VIRB Mobile app are up to date
- Format or replace the SD card
Make sure that the SD card is inserted all the way into the Garmin Dash Cam device. If it is not, the device will display an error message. It is easiest to use a fingernail to press the SD card into the slot at the bottom of the device until a click is heard.
The Dash Cam device cannot record video if connected to a computer, the Gallery app is open on the device, and/or the device has been placed into sharing mode with the Garmin VIRB Mobile app.
Closing the app will not be sufficient to end sharing mode if the device is connected to the Garmin VIRB Mobile app on your phone to share footage. It will be necessary to exit the sharing mode on the device itself.
The Dash Cam is recording if the LED in the lower-left corner is solid red.
See Indication that a Garmin Dash Cam is Recording Video for more information.
Event Detection may be disabled if the Dash Cam device is not saving video of events (e.g. collisions or sudden stops).
To check Event Detection settings:
- Ensure the device is turned on
- Press the
up button (second from top) on the right edge of the device
- Press the
select button (first from bottom) to open the Settings page
- Select Camera
- Press the
down button. Event Detection will be highlighted
- Press the
select button if there is no checkmark next to Event Detection
- Press the
back button (first from top) to save changes
The Dash Cam device will now automatically save video when it detects an event.
The Garmin Dash Cam device may not be able to record footage onto incompatible SD cards. Click the link below applying to your device for more info:
The software of your Garmin Dash Cam device can be updated using either the VIRB Mobile app on a smartphone or Garmin Express on a computer. See below for instructions.
Search for the VIRB Mobile app in the App Store or Google Play Store to see if updates are available for the app.
The SD card may need to be formatted to record more footage if it contains corrupted data. See null.
You may need to replace the card if the Dash Cam still shows no videos recorded after formatting the card or if the card cannot be formatted. See SD Memory Card Sizes for Automotive Devices for information about recommended card sizes.
Contact Product Support if the Dash Cam continues to fail to record any video.
