Requirements to Install a Garmin Running Power App on a Garmin Watch
The following are requirements and recommendations to install a Garmin running power app from the Connect IQ Store to a watch that does not natively support the feature.
NOTE: Device that support native running power do no require the Garmin's running power apps. See Garmin Running Power Device Requirements for more information.
Ensure you have the necessary Garmin devices to support running power. For more details, see - Device Requirements to Use Garmin's Running Power Apps.
There are several Garmin running power apps available. Try the basic one first that simply shows your current running power. The other apps enable you to view related metrics like lap running power, last lap running power, or average running power. For a description of the different apps, see - Breakdown of Connect IQ Running Power Apps.
Once you have downloaded your running power app(s) to your watch, you need to add the running power data field to your data screens. This is done in the watch menu under Run Settings > Data Screens.
