Denna artikel finns inte tillgänglig på ditt aktuella språk. Du kan välja ett annat nedan.
Using Dash Cam Auto Sync to Connect Multiple Garmin Dash Cams with the Garmin Drive App
Dash Cam Auto Sync in a multiple camera network (multi-cam network) allows any combination of up to four of the Garmin Dash Cams below to be paired simultaneously with the Garmin Drive™ app. This allows you to install multiple dash cameras in the same vehicle, such as front and rear cameras, and create composite picture-in-picture videos from the simultaneous recordings of two of those cameras.  The Garmin Dash Cam™ Tandem has two lenses. This allows you to have up to eight lenses recording video at the same time if you have four Garmin Dash Cam Tandems.  See the Note below for possible exceptions.
  • Garmin Dash Cam™ X110
  • Garmin Dash Cam™ X210
  • Garmin Dash Cam™ X310
  • Garmin Dash Cam™ 46
  • Garmin Dash Cam™ 47
  • Garmin Dash Cam™ 56
  • Garmin Dash Cam™ 57
  • Garmin Dash Cam™ 66W
  • Garmin Dash Cam™ 67W
  • Garmin Dash Cam™ Live
  • Garmin Dash Cam™ Mini
  • Garmin Dash Cam™ Mini 2
  • Garmin Dash Cam™ Mini 3
  • Garmin Dash Cam™ Tandem
This Video Provides a Quick Look at Dash Cam Auto Sync (formerly Dash Cam Video Sync):
For instructions on pairing multiple cameras in the Garmin Drive app, see the Pairing with Your Smartphone section in the Owner’s Manual for your dash cam.
See Bluetooth Garmin Dash Cam and Garmin Drive App Troubleshooting if there are issues with pairing your dash cam(s).
NOTE:  Bluetooth Limitations of Your Smartphone May Impact the Maximum Pairings
If you're unable to pair and connect with up to four dash cams, check the number of active and paired devices in your Bluetooth settings and compare it with the limits in the table below. Removing unused paired devices or disconnecting from devices not currently in use may help resolve the issue.
Bluetooth Connection Limits by Type
Type Maximum Paired Devices Maximum Active Connections Notes
Bluetooth Low Energy (BLE) ~103-5Primary connectivity method for Garmin Dash Cams
Bluetooth Classic (BT) ~20–307 (theoretical) | 3–4 (practical)Secondary connectivity method for Garmin Dash Cams 47 | 57 | 67W | Mini 2.  Use of these models will result in two connections each: one BLE and one BT
Total Devices ~30+3-7Varies by phone manufacturer, model and operating system version
Relaterad
