Getting Started With the inReach Messenger
If you are setting up an inReach Messenger for the first time, the following steps will walk you through the process to help you get the most out of your new Garmin.
Setting up the inReach Messenger
When powering on the Garmin for the first time, you will be prompted to configure some settings and activate with an inReach subscription.
- Power on by holding
on the right side of the device.
Choose your language by scrolling through the list using the
or
buttons, then press OK to select a language.
Pair your inReach Messenger with your phone and activate an inReach satellite subscription using the Garmin Messenger app.
For more help with pairing, see - Pairing Your Phone and Activating an inReach Messenger.
Learn More About the inReach Messenger
The following articles will help you explore and use the many features of the inReach Messenger.
inReach Features
NOTE: Before leaving for a trip, it is recommended to test that you can send out a text message. For instructions, see - null.
- Activating an inReach Subscription
- Messaging
- MapShare & Tracking
- SOS
null
Connected Features
NOTE: Before leaving for a trip, ensure that you are signed into the Garmin Messenger app and that the inReach shows as connected in the app when it is powered on and within Bluetooth range.
