Marine Batteries
Marine batteries come in three main types:
Deep Cycle:
Deep cycle batteries are designed to provide continuous power for long periods of time
Deep cycle batteries are used to power house loads that commonly include navigation aids, fish finders, running lights, radios, and trolling motors
Starting:
Starting batteries provide a short, high current burst to crank an engine
Dual-Purpose:
Dual purpose batteries can perform both deep cycle and cranking duties
Marine Battery
The "M" designation means the batteries internal construction is designed for use in a Marine application
Marine batteries use thicker internal lead plates than an automotive battery, allowing the Marine battery to discharge energy over longer periods of time
Marine batteries can also be identified by the use the Marine Cranking Amps (MCA)
MCA tests are conducted right at freezing (32*F or 0*C) for 30 seconds without falling below 7.2v at the battery MCA rating
NOTE: Every vessel has different MCA and Amp Hour requirements. To determine the MCA and Amp Hour requirements of a specific vessel, consult the vessel OEM or an authorized Marine Technician.
What is a BCI Number?
Commercially manufactured batteries adhere to a sizing standard called the "BCI Group Number", which is established by the The Battery Council International (BCI)
The BCI number refers to the physical dimensions of the battery
NOTE: If the BCI number is higher on the same type of battery, the Amp Hours may also be rated at a higher level.
Common Marine Battery Group Sizes: "M" BCI Group # by Length, Width and Height
Group Size | Length | Width | Height |
22NF | 9-7/16” | 5-1/2” | 8-15/16” |
24M | 10-1/4” | 6-13/16” | 9-3/4” |
25 | 9-1/16” | 6-7/8” | 8-7/8” |
27M | 12-1/2” | 6-13/16” | 9-3/4” |
31M | 13" | 6-13/16” | 9-7/16” |
34M | 10-1/4” | 6-13/16” | 9-7/16” |
35 | 9-1/16” | 6-7/8” | 8-7/8” |
65 | 12-1/6” | 7-9/16” | 7-9/16” |
NOTE: Measurements in the chart above may change between battery OEM. Users must ensure they check the exact measurements of the battery they are using.
NOTE: When selecting a battery, ensure it meets the functional requirements for physical size, post connections, amps, and type of battery.
Lead Acid vs AGM vs Lithium Batteries
- There are several websites on the internet that can be used to inform and help a user decide what the pros and cons are for of each type of battery
NOTE: Users should be aware and know the exact type of battery charger the vessel is equipped with, because battery chargers are designed to charge up to a certain number of batteries and may not be able to charge AGM or Lithium batteries.
