Can I Pair More Than One Device to the Garmin Connect App?
The Garmin Connect App will allow multiple devices to be concurrently paired and available for syncing. If you have one device that you use to track all-day wellness data and another device that you use only for tracking timed activities, refer to the TrueUp article to ensure your fitness trackers are setup properly in your Garmin Connect app: What Is the Garmin Connect Trueup Feature and How Does It Work?.
NOTE: The Garmin Connect app is intended for syncing one user's data, not multiple users on one account. The app will only connect and sync one device at a time. If multiple devices are capable of activity tracking, you will need to designate one of the devices as your preferred activity tracker. To learn how to select your preferred activity tracker see the Related Content.
Relaterad
