If you're setting up a fenix 6X Pro Solar for the first time, the following steps walk you through the process to help you get the most out of your new watch.
Setting up the fenix 6X Pro Solar
When powering on the watch for the first time, you'll be prompted to configure your user setting and preferences on the watch. These settings can be changed at any time.
1. Power on the watch by holding LightClick here to learn about the buttons |
| 2. Choose your language by scrolling through the list using Up and Down, press Start to select the language |
3. Pair the watch to your smartphone with the Garmin Connect App (optional)Click here for help with Bluetooth Pairing |
| 4. Proceed through the onscreen prompts to select your preferences and user settings |
5. Setup the Activity Menu by selecting your favorites (optional)Click here to learn how to set your favorite activities- Press Start to access the Activity Menu
- Use Up and Down to scroll through the list of available activity types
- Press Start to select each activity you wish to use
- Select Done when finished
Learn More About the fenix 6X Pro Solar
The following articles will help you explore and use the many features of the fenix 6 Pro Solar.
Solar Charging Features
Connected Features
Music Features
Battery Features
Training Features
Customizing the fenix 6X Pro Solar
