Denna artikel finns inte tillgänglig på ditt aktuella språk. Du kan välja ett annat nedan.
What Do the Watch Face Icons on My Garmin Watch Mean?
There are a number of options for data to be displayed on the watch face of your Garmin® watch. Below is a list of icons and their meaning.
NOTE: The listed icons below are not available on all Garmin watches. The selected watch face may change what can be customized, what options are available, or how the data appears. Refer to your owner's manual for more information.
Icon Examples
Circle surrounding a dot with a triangle cut out of the top left corner above the number 783Acute Load
Black circle showing barometer trend
Atmospheric Pressure in Millibars
The barometer trend line considers the last 6 hours, broken into two 3 hour segments. If there is a 2.3 millibar change over the 3-hour segment, the line will curve up or down depending on the direction of change.
Cloud with one arrow pointing away and one arrow point to the cloudBarometric Pressure
Black circle showing current battery levelBattery Level
Person with arms raised and semi-circle over their headBody Battery™ Data
Bluetooth connected phoneBluetooth Connected
bluetooth disconnectedBluetooth Disconnected
Black circle showing next calendar appointmentCalendar Appointment Time & Date
Black circle showing current calories burnedCalories Burned
Person on a bicycle and 0.0 underneathCycling Distance for the Current Week
Black circle showing date and monthDate & Month
Black circle showing day and dateDay of the Week & Date
Scuba diver with a check mark on the lower left corner Dive Readiness
forerunner intensity minutesEarned Intensity Minutes
Black circle showing elevationElevation
Heart with a circle around it and a star in the top right corner of the circleEndurance Score
Calendar with an hourglass in the bottom right cornerEvent Countdown
Black circle showing current floors climbedFloors Climbed
Black circle showing current heart rateHeart Rate
Person running with a triangle in the bottom right cornerHill Score
Black circle showing a heart with a jagged lineHRV Status
Black circle with arrows pointing to the rightMove Alert Bar
Person swinging golf club
Last Round of Golf
Total Score/Score to Par
Black circle showing current number of notifications on phonePhone Notifications
Circle with an X inside and numbers showing percentagePulse Ox
Black circle showing recovery time Remaining Recovery Time
Several lines depicting wind and numbers showing breaths per minuteRespiration Rate
Black circle showing weekly running distanceRunning Distance for the Current Week
Sun with lightning bolt symbol inside and a circle around the outside Solar Intensity
Black circle showing step countStep Count
Body Outline with Lightning Bold and Number 29Stress
Black circle showing the time of sunsetSunset & Sunrise
Watch Face TimerTimer
Black circle showing running man with checkmarkTraining Readiness
Black circle showing current number of notifications on phoneTraining Status
Black circle showing universal time coordinatedUniversal Time Coordinated (UTC)
Also known as Greenwich Mean Time
VO2 FR955VO2 Max
Black circle showing weather conditionsWeather Conditions & Temperature
