Garmin Connect App Instructions
Open the Garmin Connect app.
Access the menu.
Android: Select
(top left).iOS: Select More (bottom right).
Select Activities.
Select Multisport.
Select the activity you want to edit.
Select the 3 dot icon in the upper right.
Select Edit Activity.
Select Edit Legs.
Select the leg you want to edit.
Update the leg Time or Distance information.
Select Next at the bottom to edit other legs or select Done to save your changes.
Garmin Connect Web Instructions
Sign into Garmin Connect from a personal computer.
Select Activities from the navigation bar on the left.
Select All Activities.
Select the title of the multisport activity you want to edit.
Select
to edit the activity.Select Edit Legs.
Select the leg you want to edit from the drop down.
Select Edit.
Select Next to edit other legs or select Save to save changes.
