Common Vehicle Power Cable Specs and Lengths for Automotive Devices
Below are cable lengths for common vehicle power cables packaged and used with Garmin automotive devices.
Select the desired item's link below, then select the Compatible Devices tab to verify compatibility with your device.
NOTE: FMI cable lengths are estimated.
Cable Information
Automotive Mount Kit for Tread 2 and zumo XT2 Vehicle power cable, type USB-C to USB-A Used with 12V, 2.4A, USB-A socket power adapter (included) | 4.92 feet (1.5 meters) | ||||||||||||
18 feet (5.5 meters) | |||||||||||||
12.91 inches | |||||||||||||
Equivalent replacement - 010-12982-05 | 5 feet (1.5 meters) | ||||||||||||
Dual USB Power Adapter (included with most Garmin Dash Cams) Vehicle power cable - long Vehicle power and data cable - short | 13.12 feet (4 meters) 5 feet (1.5 meters) | ||||||||||||
Extra-Long Power Cable (for most Garmin Dash Cams) | 26 feet (8 meters) | ||||||||||||
18 feet | |||||||||||||
FMI 15 Data Cable | 6.5 feet (approximate) | ||||||||||||
FMI 25 Cable | 10 feet (approximate) | ||||||||||||
FMI 35 Serial Data Cable with FM Antenna | 10 feet (approximate) | ||||||||||||
10 feet (approximate) | |||||||||||||
FMI 65 Data and HD Traffic Cable | 4.4 feet (approximate) | ||||||||||||
Garmin DriveSmart™ 65 with Amazon Alexa Vehicle Power Cable with Extra USB Charging Port | 5.5 feet (1.68 meters) | ||||||||||||
13.12 feet (4 meters) | |||||||||||||
Garmin PowerSwitch ground cable, black, gauge 10AWG (cable is not sold separately) | 36 inches | ||||||||||||
Garmin PowerSwitch power cable, red, gauge 4AWG (cable is not sold separately) | 34 inches | ||||||||||||
5 feet | |||||||||||||
GTM 60 HD traffic receiver cable | 5 feet | ||||||||||||
11 feet 6 inches | |||||||||||||
4.3 inches | |||||||||||||
RV 890 | RV 895 | RV 1090 | RV 1095 GPS navigators 12/24V Car Charger (320-01372-00) Equivalent replacement - 010-12982-05 | 5 feet (1.5 meters) | ||||||||||||
5.5 - 5.75 feet | |||||||||||||
4.92 feet (1.5 meters) | |||||||||||||
6.3 feet (1.93 meters) | |||||||||||||
zūmo XT Motorcycle Power Cable
zūmo XT2 Motorcycle Power Cable
| 6.5 feet (1.98 meters) |
See Cable Lengths for the BC 20 and BC 30 for lengths of cables in the BC 20 and BC 30 backup camera kits.
See for lengths of cables for the BC 35 backup camera.
See Cable Lengths for the BC 50 Wireless Backup Camera for lengths of cables for the BC 50 Wireless Backup Camera series.
See Garmin Catalyst Cables for lengths of cables for the Garmin Catalyst Driving Performance Optimizer.
See Common USB Cable and AC Adapter Lengths for Automotive Devices for other automotive cable lengths.
See Antenna Lengths for Tread Series and zūmo XT Series Devices for Tread and zūmo antenna lengths.
